"90 Fleetwood waterpump?
Old 01-08-2007, 05:45 PM
dragons65's Avatar
Default "90 Fleetwood waterpump?
Just how difficult to replace? Thanks
Old 01-08-2007, 06:53 PM
brougham1's Avatar
Default RE: "90 Fleetwood waterpump?
Hey Dragon: Water pump not that big of a deal to remove and replace. Take the neg. battery terminal off before you start. Drain rad.,reach inside fan shroud and remove fan blade bolts. Remove shroud now to make it easier to get at pump. Loosen drive belts, any mounting brackets attached to pump, disconnect lowwer rad hose. Make sure to clean the engine surface well before replacing and use a gasket sealant on the gasket as you don't want to have to do this again because of a leak. Good luck...................
Old 01-08-2007, 08:27 PM
dragons65's Avatar
Thanks for the info. I'll give it a shot.
Karen
01-19-2014 02:35 PM
dgi
11-22-2010 09:36 AM
wpbrink
05-08-2007 08:59 PM
toms46
10-11-2006 09:32 PM
Quick Reply: "90 Fleetwood waterpump?
