Service / Parts Identification
Does anyone know where i can go online to see what the service parts identification codes listed inside the glove box of my 05 ESV Platinum refer to? example: Y91 - is this for the Radio/CD/Navigation head unit with out the reverse camera? I would like to cross referance the numbers so i can find some correct parts.
RE: Service / Parts Identification
GM Service Information 05 ESV
RPO Table RPO
Description
The production/process codes provide the description of the Regular Production Options (RPOs). The RPO list is printed on the Service Parts Identification Label.
AC6
Window Tinted Deep, Rear, S/D
AE7
Seat FRT Split, Driver, PASS
AG1
Adjuster FRT ST Power, Multi-Directional, Driver
AG2
Adjuster PASS ST Power, Multi-Directional
AJ1
Windows Deep Tint, All Except W/S And DRS
AJ7
Restraint System Seat, Inflatable, Driver and Passenger, Front and Side
AL0
Sensor Indicator Inflatable Restraint, Front Passenger/Child Presence Detector
AL4
Seat RR BKT
ANJ
Window Tinted Export Compliant, Non-Deep
AN3
Seat FRT, Individual (Non BKT)
AP9
Net Convenience
ARL
Plant Code Arlington, TX USA
AS3
Seat RR
AT5
Seat Rear CTR, Folding
AU0
Remote Function Actuation - Keyless Entry - Domestic
AU3
Lock Control Side Door, Electric
AU8
Remote Function Actuation, Specific Frequency
AX4
Restraint Conversion Seat, Manual, European
A04
Windshield Tinted, Less Upper Shadeband
A31
Window Power Operated, All Doors
A95
Seat FRT BKT, High Back, Driver and PASS RECL
BAG
Parts Package Export
BG9
Rubber Floor Covering
BPH
Appearance Package Chevrolet Off Road
BS1
Insulation Acoustical PKG
BVE
Side Steps Runningboard
BVF
Side Steps Runningboard, Color Keyed
BVQ
Side Steps Runningboard, Tubular Chrome
BVR
Side Steps Runningboard, Tubular Stainless Steel
BVS
BW1
Ornamentation Exterior Rear End
BW2
Molding B/S Deluxe
BX2
Molding B/S Lower, Extra Wide
B30
Floor Covering Carpet
B37
Covering Floor Mat, Front and Rear, Auxiliary
B39
Covering Floor Carpet, Load Floor
B41
Covering Floor Mat, Load Floor
B58
Covering Floor MAT, FRT And RR, Carpeted Insert
B71
Wheel Opening Flares
B85
Molding - Body Side , Exterior, Bright
B96
Molding Wheel Opening
CF5
Roof Sun Glass, Sliding, Electric
CJ2
HVAC System Air Conditioner Front, Auto Temperature Control, Auxiliary Temperature Control
CJ3
HVAC System Air Conditioner Front, Manual Temperature Control, Auxiliary Temperature Control
C25
Wiper System, Rear Window, Intermittent
C36
Heater Auxiliary
C49
Defogger RR Window, Electric
C5H
GVW Rating 6,900 LBS
C5U
GVW Rating 6,800 LBS
C5W
GVW Rating 7,000 LBS
C5Z
GVW Rating 7,200 LBS
C6P
GVW Rating 8,600 LBS/3,900 KG
C69
HVAC System Rear Air Conditioner
C7K
GVW Rating 6,500 lbs
DF5
Mirror, I/S R/V LT Sensitive, Compass, O/S Temp Display
DH6
Mirror, I/S Front Van, LH And RH, Illumination with Sunshade
DK7
Console Roof Interior, Custom
DK8
Console Roof Interior, Deluxe
DL3
Mirror, O/S LH and RH, Remote Control, Electric, Heated, Power Folding, Turn Signal Indicator, Light Sensitive, Color
DL8
Mirror, O/S LH And RH, Remote Control, Electric, Heated
DNR
Equipment, Dealer Installed
DPF
Mirror, O/S LH and RH, Wide Load, Remote Control, Electric, Heated
DR4
Mirror, O/S LH and RH, Remote Control, Electric, Heated, Light Sensitive, Power Folding, Color
DT3
Rear Box Compartment, Stowage
DT4
Ashtray, Cigarette Lighter
DUF
Equipment, Duffle Bag and Daypack
D07
Console Front Compartment, Floor, Custom
D31
Mirror I/S R/V Tilt (Duplicate with D36)
D55
D99
Body Provisions for Special Two Tone Paint
EN4
Cover, Rear Compartment Hard, Rear Compartment, Cargo
EVA
Test DVT, EVAP Emission Requirement
E37
Pickup Box, Inner DK Composite
E52
Body Equipment One Piece Lift Gate With Lift Glass
E95
Cover, Rear Compartment Tonneau, Rear Compartment
FF4
Arm, Left Torsion Bar Spring Adjustment (C)
FF5
Arm, Right Torsion Bar Spring Adjustment (D)
FF6
Arm, Left Torsion Bar Spring Adjustment (E)
FF7
Arm, Right Torsion Bar Spring Adjustment (F)
FK2
Arm, Left Torsion Bar Spring Adjustment (A)
FK3
Arm, Right Torsion Bar Spring Adjustment (B)
FT2
Arm, Left Torsion Bar Spring Adjustment (FT2)
FT3
Arm, Right Torsion Bar Spring Adjustment (FT3)
F0F
Fleet Incentive Tourism Industry Inc. DBA Budget Sales and Leasing
F60
Spring Front Heavy Duty
GND
Sales Package Avalanche Ground Affects
GT4
Axle Rear 3.73 Ratio (DUP With 5 x 1)
GT5
Axle Rear 4.10 Ratio (DUP With GT8)
GU6
Axle Rear 3.42 Ratio
G63
Provisions, Luggage Carrier, Roof
G65
Level Control Manual, Self-Adjusting
G69
Level Control Auto, Air, HD
G80
Axle Positraction Limited Slip
G86
Axle, Limited Slip
JAN
Plant Code Janesville, WI, USA
JE1
Brake System, Europe
JF4
Power Adjustable Pedals
JH2
Brake Hyd Power, Disc/ Disc, 7,200 lb
JH6
Brake Hyd Power, 4-Wheel Disc, 9,900 lb
JL4
Control Active Brake
J81
Indicator Switch, Export
KA6
Rear Seat Heater
KC4
Heavy Duty Engine Oil Cooling
KG3
Generator 145 Amp
KNP
Cooling System Trans, HD
KUP
Throttle Control Electronic
K05
Heater Engine Block
K34
Cruise Control, Automatic, Electronic
K47
Air Cleaner High Capacity
K68
Generator 105 Amp
LM7
Engine Gas, 8 CYL, 5.3L, MFI, Iron, GM
LQ4
Engine Gas, 8 CYC, 6.0L, MFI, Iron, GM
LQ9
Engine Gas, 8 CYC, 6.0L, MFI, Iron, GM, HO
LR4
Engine Gas, 8 Cechy, 4.8L MFI, Iron, GM
L18
Engine Gas, 8 CYL, 8.1L, MFI
L59
Engine Flexible Fuel (Gas/Alc), 8 cyl, 5.3L, MFI, V8, GM
MN8
Transmission Auto 4-Speed, HMD, 4L80-E, Heavy Duty
MSL
Plant Code, Silao, Mexico
MTF
Provisions, Fire Extinguisher Mounting
MT1
Transmission 4-Speed Auto W/Elect Controls H.D. - Hydra-Matic 4L80-E
M30
Transmission Auto 4-Speed, HMD, 4L60-E, Electronic
M32
Transmission Auto 4-Speed Hydra-Matic Drive, 4L60-E Electronic, HD
NA1
Emission System GVW less than 8, 500 lb
NA4
Emission System GVW greater than 8, 500 lb
NC1
Emission System California, LEV
NF4
Emission System Clean Fuel Fleet
NF9
Emission System General Unleaded
NK5
Steering Wheel, Standard
NP5
Steering Wheel, Leather Wrapped
NP7
Steering Column, EEC Approved
NP8
New Venture Gear 246
NR3
Transfer Case - All Wheel Drive (AWD), Open Differential, Single Speed
NR4
Transfer Case - 4 Wheel Drive (4WD), Open Differential, 2 Speed
NT3
Emission System EEC 00
NT8
Emission System, Federal, Tier 2 A
NT9
Emission System Federal, Tier 2 Phase-out
NU4
Emission System, California LEV2 Plus
NW7
Traction Control - Electronic
NYS
Steering Four Wheel
NZZ
Skid Plate Off-Road
N12
Exhaust System Rear Exit
N30
Steering Wheel Deluxe
N88
Wheel - New - Aluminum - 17 x 7.5, Premium
N89
Wheel - New - Aluminum - 17 x 7.5, Sport
N93
N94
Wheel - New - Aluminum - 17 x 7.5, Chrome
PF4
Wheel - Cast - Aluminum- 16 X 7.0
PF9
PY0
Wheel - New - Aluminum - 16 X 6.5
PY2
Wheel 16 X 6.5 Chrome Appearance
P03
Wheel Cover, Var 3
P25
Wheel 17 X 7.5 Aluminum 5-Spoke Premium
P27
Wheel 17 X 7.5 Aluminum 6-Spoke Premium
P96
Equipment Mexican Modified, Mandatory Base Equipment
QAN
Tire All P265/70R 17 - 113S BW R/PE ST TL AL2
QAQ
Tire All P265/70R 17 - 113H BW R/PE ST TL AL2
QAS
Tire All P265/70R 17 - 113S WOL R/PE ST TL AL2
QB5
Wheel 16 x 6.5, Steel
QCP
Tire All P255/70R 16 - 109H BW R/PE ST TL ALS
QIW
Tire All LT245/75R16E R/PE ST TL OOR BL
QIX
Tire All LT265/75R16/C BW R/PE ST TL OOR 12OQ
QIZ
Tire All LT245/75R16/E BW R/PE ST TL OOR 12OQ
QJM
Tire All P265/70R17 - 113SWOL R/PE ST TL OOR
QJP
Tire All P265/70R17 - 113S BW R/PE ST TL OOR
QLP
Tire All LT2465/75R16/E BW R/PE ST TL ALS 120/116S
QMJ
Tire All P265/70R16 - 111S BW R/PE ST TL AL2
QMK
Tire All P265/70R16 - 111S WOL R/PE ST TL AL2
QNK
Tire All P245/75R16 - 109S BW R/PE ST TL ALS
QNL
Tire All P465/75R16 - 109S WOL R/PE ST TL ALS
RYJ
Shade Cargo Area, Retractable
R4W
Tire Brand All, Michelin
R4Y
Tire Brand All, Goodyear
R5C
Tire Brand All, Bridgestone
SAF
Lock, Spare Tire, Hoist Shaft
SLT
Equipment Chevrolet LT Sales Package
TL1
Grille Special
TRB
Grille Radiator, Body Color
TRW
Provisions Lamp, Roof Mounted
TR2
Lamp Turn Signal, Enlarged
TR3
Grille Radiator, Body Color w/Chrome Emblem
TR6
Headlamps Control Leveling System, Manual
T2H
Ornamentation Exterior, Export Unique Requirements
T2J
Ornamentation Interior, Export Unique Requirements
T62
Daytime Running Lamp System - Delete
T74
Headlamps Control Automatic, Delay
T78
Headlamps Control - Delete
T79
Rear Fog Lamp
T84
Headlamps, Right Hand Rule of the Road, E Mark
T89
Lamp, Tail and Stop, Export
T9H
Provisions Lamp, Front Fog
T96
Fog Lamps - Front
UB0
Radio AM/FM Stereo, Seek/Scan, CD, Auto Tone, Data System, Clock, ETR
UB1
Radio AM/FM Stereo, Seek/Scan, Auto Reverse Music, Search Cassette, CD, Auto Tone, Data System, Clock, ETR
UC2
Speedometer Instrument, Kilometers and Miles, Kilometer Odometer, Positive Bias
UC6
Radio AM/FM Stereo, Seek/Scan, RDS, Multiple Compact Disc, Auto Tone Control, Clock, ETR
UD4
Alarm, Vehicle Speed, 120 K/H
UD7
Sensor Indicator Rear Parking Assist
UE1
Communication System Vehicle, G.P.S. 1
UG1
Garage Door Opened, Universal
UG2
Garage Door Opened, Universal - Delete
UJ6
Indicator, Low Tire Pressure
UK3
Control Steering Wheel, Accessory
UK6
Radio Control RR Seat And Earphone Jacks
UL2
Frequencies, European
UL4
Frequencies, South America
UL8
Frequencies, Saudi Arabian
UM7
Radio - AM/FM Stereo, Seek/Scan Clock, ETR
UM8
Radio - AM/FM Stereo, Seek/Scan CD, ETR, Navigation Clock
UQ3
Speaker System, Performance Enhanced Audio
UQ7
Speaker System Premium Performance, Enhanced Audio, Bose®
U01
Roof Marker Lamps
U1S
Player Multiple Compac Disc
U19
Speedometer INST, Kilo And Miles, Kilo Odometer
U2K
Digital Audio System S-Band
U34
Display Celsius Temperature
U42
Entertainment Package Rear Seat
U84
Antenna, Body Side Window, Radio
VBX
Language Label Arabic
VB3
Bumper Rear Step, Chrome, Impact Strip
VB5
Bumper Front, Color
VC4
Label Price/Fuel Economy, Puerto Rico and Virgin Islands
VC5
Label Shipping, Except US, US Possessions, or Japan
VC7
Label Price/Fuel Economy, Guam
VD1
Provision Options, Europe
VFF
Video Format Region 1, NTSC
VFJ
Video Format Region 2, PAL
VFK
Video Format Region 3, NTSC
VFM
Video Format Region 4, NTSC
VFP
Video Format Region 5, PAL
VGC
Protector Film, Paint Etch Preventive
VG3
Bumper Front Impact Strip
VG8
Vehicle Label, Notice to Buyer
VJ3
Label, Plate ECE Approval and Vehicle Identification
VK3
License Plate, Front Mounting Package
VPH
Vehicle Preparation - Overseas Delivery
VP6
Noise Control
VR4
Trailer Hitch Weight Distributing Platform
VR6
Hook, Tie-Down, Shipping
VR7
Hook, Tow, Second Rear
VT4
Bumper Front Color Keyed
VT5
Bumper Rear Color Keyed
VXS
Vehicle Complete
VZ2
Calibration Speedometer A
VZ3
Label, Mercury Disposal Notification
V1K
Luggage Carrier Bar, Center Cross
V20
Guard Radiator, Grille, Black
V22
Grille Radiator, Chrome
V3A
Guard Radiator, Grille, Gray and Chrome
V43
Rear Bumper Step, Color
V54
Roof Luggage Carrier, Painted
V73
Vehicle Statement, USA/Canada
V76
Front Towing Hook
V78
Vehicle Statement - Delete
V87
Vehicle Statement, Gulf States Organization
V92
Trailer Provisions
V98
Factory Delivery Processing
WBH
Merchandised Package, Base Decor
WV9
Merchandised Package, Value Leader
XAN
Tire Front P265/70R17-113S BW R/PE ST TL AL2
XAQ
Tire Front P265/70R17-113H BW R/PE ST TL AL2
XAS
Tire Front P265/70R17-113S WOL R/PE ST TL AL2
XCP
Tire Front P255/70R17-109H BW R/PE ST TL ALS
XGK
Tire Front LT245/75R16/E BW R/PE ST TL OOR 120Q
XHH
Tire Front LT245/75R16/E BW R/PE ST TL ALS 120Q
XHS
Tire Front P265/75R16-114H BW R/PE ST TL AT A Temp
XJM
Tire Front P265/70R17-113S WOL R/PE ST TL OOR
XJP
Tire Front P265/70R17-113S BW R/PE ST TL OOR
XLP
Tire Front LT245/75R16/E BW R/PE ST TL ALS 120/116S
XMJ
Tire Front P265/70R16-111S BW R/PE ST TL AL2
XMK
Tire Front P265/70R16-111S WOL R/PE ST TL AL2
XNK
Tire Front P245/75R16-109S BW R/PE ST TL ALS
XNL
Tire Front P245/75R16-109S WOL R/PE ST TL ALS
X88
Conversion Name Plate Chevrolet
YAN
Tire Rear P265/70R17-113S BW R/PE ST TL AL2
YAQ
Tire Rear P265/70R17-113H BW R/PE ST TL AL2
YAS
Tire Rear P265/70R17-113S WOL R/PE ST TL AL2
YCP
Tire Rear P255/70R16-109H BW R/PE ST TL ALS
YE9
Convenience Package Comfort and Decor Level #3
YGK
Tire Rear LT245/75R16/E BW R/PE ST TL OOR 120Q
YHH
Tire Rear LT245/75R16/E BW R/PE ST TL ALS 120Q
YHS
Tire Rear P265/75R16-114H BW R/PE ST TL AT A Temp Rating
YJM
Tire Rear P265/70R17-113S WOL R/PE ST TL OOR
YJP
Tire Rear P265/70R17-113S BW R/PE ST TL OOR
YLP
Tire Rear LT245/75R16/E BW R/PE ST TL ALS 120/116S
YMJ
Tire Rear P265/70R16-111S BW R/PE ST TL AL2
YMK
Tire Rear P265/70R16-111S WOL R/PE ST TL AL2
YNK
Tire Rear P245/75R16-109S BW R/PE ST TL ALS
YNL
Tire Rear P245/75R16-109S WOL R/PE ST TL ALS
Y91
Merchandised PKG Luxury Edition
Y92
Merchandised PKG Special Edition
ZCP
Tire Spare P255/70R16-109H BW R/PE ST TL ALS
ZGC
Tire Spare P265/75R16-114S BW R/PE ST TL AT
ZGK
Tire Spare LT245/75R16/E BW R/PE ST TL 00R 120Q
ZHH
Tire Spare LT245/75R16/E BW R/PE ST TL ALS 120Q
ZHS
Tire Spare P265/75R16-114H BW R/PE ST TL AT A Temp Rating
ZLP
Tire Spare LT245/75R16/E BW R/PE ST TL ALS 120/116S
ZMJ
Tire Spare P265/70R16-111S BW R/PE ST TL AL2
ZMK
Tire Spare P265/70R16-111S WOL R/PE ST TL AL2
ZM9
Sales Package Comfort & Convenience
ZNK
Tire Spare P245/75R16-109S BW R/PE ST TL ALS
ZNL
Tire Spare P245/75R16-109S WOL R/PE ST TL ALS
ZQ1
Chassis Package Smooth Ride
ZW7
Chassis Package Premium Smooth Ride
ZW9
Base Body or Chassis
ZY1
Color Combination, Solid
Z49
Export Canadian Modified, Mandatory Base Equipment
Z5X
Mirror Provisions, Arabic Language
Z55
Chassis Package Bi-State, Real Time Damping
Z66
Appearance Package Premium Ride Suspension
Z71
Chassis Package Off Road
Z75
Conversion Name Plate Cadillac
Z82
Trailer Provisions Special Equipment, H. D.
Z85
Chassis Package Increased Capacity
Z88
Conversion Name PLT GMC
Description
AC6
AE7
AG1
AG2
AJ1
AJ7
AL0
AL4
Seat RR BKT
ANJ
AN3
AP9
Net Convenience
ARL
AS3
Seat RR
AT5
AU0
AU3
AU8
AX4
A04
A31
A95
BAG
BG9
BPH
BS1
BVE
BVF
BVQ
BVR
BVS
BW1
BW2
Molding B/S Deluxe
BX2
B30
B37
B39
B41
B58
B71
B85
B96
CF5
CJ2
CJ3
C25
C36
Heater Auxiliary
C49
C5H
C5U
C5W
C5Z
C6P
C69
C7K
DF5
DH6
DK7
DK8
DL3
DL8
DNR
DPF
DR4
DT3
DT4
DUF
D07
D31
D55
D99
EN4
EVA
E37
E52
E95
FF4
FF5
FF6
FF7
FK2
FK3
FT2
FT3
F0F
F60
GND
GT4
GT5
GU6
G63
G65
G69
G80
G86
Axle, Limited Slip
JAN
JE1
JF4
JH2
JH6
JL4
J81
KA6
Rear Seat Heater
KC4
KG3
Generator 145 Amp
KNP
KUP
K05
Heater Engine Block
K34
K47
K68
Generator 105 Amp
LM7
LQ4
LQ9
LR4
L18
L59
MN8
MSL
MTF
MT1
M30
M32
NA1
NA4
NC1
NF4
NF9
NK5
NP5
NP7
NP8
NR3
NR4
NT3
NT8
NT9
NU4
NW7
NYS
Steering Four Wheel
NZZ
Skid Plate Off-Road
N12
N30
N88
N89
N93
N94
PF4
PF9
PY0
PY2
P03
Wheel Cover, Var 3
P25
P27
P96
QAN
QAQ
QAS
QB5
QCP
QIW
QIX
QIZ
QJM
QJP
QLP
QMJ
QMK
QNK
QNL
RYJ
R4W
R4Y
R5C
SAF
SLT
TL1
Grille Special
TRB
TRW
TR2
TR3
TR6
T2H
T2J
T62
T74
T78
T79
Rear Fog Lamp
T84
T89
T9H
T96
Fog Lamps - Front
UB0
UB1
UC2
UC6
UD4
UD7
UE1
UG1
UG2
UJ6
UK3
UK6
UL2
UL4
UL8
UM7
UM8
UQ3
UQ7
U01
Roof Marker Lamps
U1S
U19
U2K
U34
U42
U84
VBX
VB3
VB5
Bumper Front, Color
VC4
VC5
VC7
VD1
VFF
VFJ
VFK
VFM
VFP
VGC
VG3
VG8
VJ3
VK3
VPH
VP6
Noise Control
VR4
VR6
VR7
VT4
VT5
VXS
Vehicle Complete
VZ2
VZ3
V1K
V20
V22
V3A
V43
V54
V73
V76
Front Towing Hook
V78
V87
V92
Trailer Provisions
V98
WBH
WV9
XAN
XAQ
XAS
XCP
XGK
XHH
XHS
XJM
XJP
XLP
XMJ
XMK
XNK
XNL
X88
YAN
YAQ
YAS
YCP
YE9
YGK
YHH
YHS
YJM
YJP
YLP
YMJ
YMK
YNK
YNL
Y91
Y92
ZCP
ZGC
ZGK
ZHH
ZHS
ZLP
ZMJ
ZMK
ZM9
ZNK
ZNL
ZQ1
ZW7
ZW9
ZY1
Z49
Z5X
Z55
Z66
Z71
Z75
Z82
Z85
Z88
jmsnyder
06-05-2021 06:41 AM
jmsnyder
09-11-2012 11:03 PM
