Onki Running Boards for your Escalade
Old 01-08-2015, 06:39 AM
carid's Avatar
Banned
Default Onki Running Boards for your Escalade
One of the simplest and most cost-effective ways to improve the function and looks of your SUV or truck is to bolt on a set of high quality Running Boards. Running boards are designed to provide extra grip and a platform for you to step in all conditions. Some running boards require drilling during the installation, while most will bolt into factory holes on your vehicle. They are generally available in two finishes: black or stainless steel.
One of the most reputable names in running boards production is Onki Corporation. Onki offers their running boards in a variety of lengths from 52 inches to 118 inches for a proper fit on all types of vehicles. So if you are looking for running boards for your Escalade, you’ll find one that fits well and looks right. Here is the list of few options we have for the 2013 Cadillac Escalade.
Onki® - 78" Nerf Boards offer the traditional look of bright metal and black rubber along with the benefits of stainless steel and aluminum construction. Aluminum frame construction provides high strength and light weight.
Onki® - 78" Volcano Running Boards - this running board’s 6.5-inch wide step framed by a 3-inch diameter steel for rigidity and strength. Hard rubber grip pads available in orange or black provide texture for secure footing, and can easily be replaced by lifting the removable top step panel.
Onki® - 78" American Runner Running Boards offer the option of lighting for running board surfaces and the ground underneath that operates when any vehicle door is opened. Aluminum frame construction ensures corrosion-free strength, and a 1.5-inch steel tube available in either polished stainless steel or black mild steel surrounds the step area for rigidity.
Once you and your passengers experience the convenience and safety these running boards provide, you’ll never want another car without them. Have you ever tried them on?
Old 01-12-2015, 04:19 AM
carid's Avatar
Banned
Hey guys!
Have you ever wondered if the running boards can be smart? Bestop® has an answer for you. They created Powerboard™ Running Board - The Smartest Running Board on the Planet!
The PowerBoard™ is an automatic running board that hides underneath your truck when doors are closed and extends to meet your foot when door opens. Hides underneath your truck when doors are closed for complete ground clearance. Works with both front and rear door, driver and passenger. Complete kit includes two steps, wiring harness with controller, weatherproof motors, LED light kit and hardware. 6.25 inch extra wide step is made with extruded aluminum with an ultra-durable powder coat that features a non-slip textured surface. All PowerBoards feature an integrated light kit, coated fasteners to resist corrosion and a heavy duty, weatherproof, pressure sensitive , pinch-proof technology motor to assure safety and workability for years to come. Each PowerBoard can hold up to 600lb load capacity PER SIDE and have been climate and salt spray tested to operate in any climate.
Make sure to check this video and see, how exactly it works:
What do you think about it?
carid
03-04-2015 07:58 AM
carid
02-18-2015 09:17 AM
420Deville
10-17-2007 09:26 AM
420Deville
09-30-2007 07:32 PM
Quick Reply: Onki Running Boards for your Escalade
