Help Needed to Clean Drain Tubes
Old 03-30-2010, 12:56 PM
05Escalade's Avatar
Default Help Needed to Clean Drain Tubes
I have an 05 Escalade and believe the drain tubes need to be cleaned. Does anyone have instructions on how to do this? I have water coming in through the passenger roof a/c-heat vent and the roof ac-heat control panel, but around the sunroof is dry. I dont understand..... Any ideas? Thank you.
Old 03-30-2010, 06:14 PM
Drains are typically "blown out" with compressed air. Drains are in the 4 corners of the pan/tray that hold sunroof. Front drains are easy to find, rears are some what of a "spray and pray" since there isn't easy access to them.
treasureoak
09-19-2007 11:28 PM
dsandmandm
06-01-2007 05:45 PM
theatreman
04-28-2007 11:32 AM
04-02-2007 11:53 AM
Quick Reply: Help Needed to Clean Drain Tubes
