2011 esky overheating
I have an 11 luxury trim escalade that overheats when towing. This is the only time it overheats. I have replaced the thermostat, water pump, coolant flush and it still overheats. I know that the fans turn on, I don't know if they are running exactly when they are supposed to or not. Does anyone have any ideas what the problem is?
thanks,
jay
thanks,
jay
Overheating
If you know anyone that has a TECK2 scanner they can go into the settings and reprogram the fans to come on sooner , have you changed the DEX-COOL antifreeze , it has been known to go bad and plug up systems , try putting in some WETTER-WATER , most auto parts places have it and it raises the boiling point . If you see bubbles in the coolant tank you might have a leaking head gasket .
membercalendars.com
09-02-2010 12:22 PM
membercalendars.com
09-02-2010 12:18 PM
