tire monitor alert - Cadillac ESCALADE TIRE MONITOR
Old 02-04-2008, 02:57 PM
reginapate's Avatar
Default tire monitor alert - Cadillac ESCALADE TIRE MONITOR
I just recently purchased a escalade and now it is showing "service tire monitor". It does have custom wheels on it. What does that mean and how do you fix it?
Old 02-04-2008, 07:19 PM
Default RE: tire monitor alert
Are tire pressure sensors there? Many times they are not, just the regular valve stems installed in custom wheels and tires. If they're not there message will be displayed.
Old 02-05-2008, 08:29 AM
reginapate's Avatar
Does it damage the car without the sensors?
Old 02-05-2008, 12:00 PM
No..........
Old 02-06-2008, 01:00 AM
ORIGINAL: reginapate
They are a safety device. What will hurt the car and you , is if the tires go under inflated and you have no tire monitors to advice you.
If YOU paid to have those custom wheels put on and the tire shop left them out, OUCH !
You aint gonna believe what they cost to replace ...
Old 02-08-2008, 09:50 PM
rafael nazario's Avatar
Default RE: tire monitor alert - Cadillac ESCALADE TIRE MONITOR
I had the same problem. Assuming that the sensors are installed. You may need to replace the monitor which is located on the passenger door window and lock control. I did it and it worked. Know, the situation I have is that it also control the remote controls and I haven't been able to program the remotes. So, if you can live with the message don't do anything.
Old 10-27-2012, 10:54 PM
NiCad's Avatar
Can you remove the sensors from the 04 EXT wheel and install them in the 07 EXT wheel?
99STSGUY
09-16-2009 12:51 PM
rafael nazario
05-10-2009 10:23 PM
jim
11-30-2007 12:10 AM
Refugeez
04-07-2007 01:17 PM
EldoLady
10-17-2006 04:01 PM
Quick Reply: tire monitor alert - Cadillac ESCALADE TIRE MONITOR
