U1064 History and B2115 History ?
This is the first time I ran the codes on my 02 ETC and these are the only 2 that came up, U1064 History and B2115 History. Would someone please tell me what they mean? Is there some place that I can get a complete listing of the codes?
Thanks
Thanks
2002 Cadillac ETC codes
ORIGINAL: Virginia John
Thanks
Thanks
U1064- Loss of data/communicatin DIM module.
DIM= dash intergraton module
B1735 - Driver Seat Front Up Switch Circuit Malfunction (Power Seat Switch Circuit)
B1740 - Driver Seat Front Down Switch Circuit Malfunction
B1745 - Driver Seat Rear Up Switch Circuit Malfunction
B1750 - Driver Seat Rear Down Switch Circuit Malfunction
B1755 - Driver Seat Asm Forward Switch Circuit Malfunction
B1760 - Driver Seat Asm Rearward Switch Circuit Malfunction
B2355 - Driver Front Vertical Sensor Malfunction
B2365 - Driver Rear Vertical Sensor Malfunction
B2375 - Driver Seat Asm Horiz Sensor Circuit Malfunction
B2101 - Recline Aft Switch Failed ยท B2102 - Recline Forward Switch Failed
B2103 - Rear Vertical Down Switch Failed
B2104 - Rear Vertical Up Switch Failed
B2105 - Horizontal Aft Switch Failed
B2106 - Horizontal Forward Switch Failed
B2107 - Front Vertical Down Switch Failed
B2108 - Front Vertical Up Switch Failed
B2109 - Lumbar Aft Switch Failed
B2110 - Lumbar Forward Switch Failed
B2111 - Lumbar Down Switch Failed
B2112 - Lumbar Up Switch Failed
B2115 - Recline Sensor Failed
B2116 - Rear Vertical Sensor Failed
B2117 - Horizontal Sensor Failed
B2118 - Front Vertical Sensor Failed
B2119 - Lumbar Forward/Aft Sensor Failed
B2120 - Lumbar Up/Down Sensor Failed
is the radio working? if not reset the codes.
if you see any other problems, I would try a 'battery reboot' of the car
01-17-2009 08:29 PM
