1989 Eldorado can't rev more than idle!
When this has occured, the check light was on, because I had a bad O2 sensor. Suddenly, as I tried to put the pedal to the metal, the engine died after what seems to be a backfire.
Since then : It runs at idle roughly, but can't rev more than 1500 rpm.
Since I have another 89 in my bacyard (working), this is what I've done :
-replaced ECM Unit
-replaced coil
-new spark plugs
-disconnect exhaust befor catalytic converter to check if it was not damaged, the problem is the same
-change every sensor under the hood
-replaced both fuel nozzles
-the fuel is okay
-ignition okay
So what should I do now ???
-replaced ECM Unit
-replaced coil
-new spark plugs
-the fuel is okay
-ignition okay
Thanks CadsForFun, I have tried these things, but it doens't fix my problem...
It s DFI (2 nozzles).
I have replaced the rotor, distributor cap too..
How should I know from the on board computer ? First af all I would like to reset the defaults codes...
Eldo
Have you pulled the codes already and what were they?? Clear them by entering the diagnostics, pushing and holding off and hi until oo appears then 70 will appear. Now you can see which codes come back when you run the car. Post them so we can go from there.
vettelover91
05-07-2012 01:29 AM
fabes
10-29-2009 12:05 AM
