multiple questions regarding 1989 eldorado
Old 02-02-2006, 01:24 AM
89Eldorado's Avatar
Default multiple questions regarding 1989 eldorado
I recently aquired a 1989 cadillac eldorado.
I had a pretty serious problem today, ingition key got stuck and wouldnt turn off, took it to shop, probaly the ignition cylinder. Anyone with similar problems?
Also, once in a while I get the "Coolant Fan Fault" and each time I check the temp it is usualy 230 or 233, it climbs to 238 then returns to normal (208-213) I had 7 occurances when it hit 238 and climbed to 254. I pulled off and let it cool down. Is this a thermostat problem???
Old 02-07-2006, 12:40 AM
Default RE: multiple questions regarding 1989 eldorado
I have a 88 eldawg and was also getting the same warning! It turned out to be the coolant fan module that sits directly behind the grill. It has four connectors coming from it and operates the fans. Unfortunately you can't get it aftermarket, and through the dealer it's rather costly $200+. I bought mine from a salvage yard for $11 and have had no problems since, this was about 9 months ago. Good luck!
Old 08-14-2006, 12:49 AM
thanks i am having the same problem i am going to go buy it in the morning i will post back to let you know but thanks again
mikeyc0120
12-07-2012 05:46 PM
cpchase
01-27-2010 09:09 PM
chain492
04-13-2008 08:51 PM
DGuess
01-08-2008 11:13 AM
jtq123
04-30-2007 05:42 PM
Quick Reply: multiple questions regarding 1989 eldorado
