Maintenance Problem
Old 02-26-2008, 10:37 AM
Virginia John's Avatar
Default Maintenance Problem
I went looking for the PCV valve on my '02 ETC today without success. I remioved the plenum cover and found what I thought was the PCV valve on the rear valve cover on the right side of the engine. It had a plastic hose with a rubber connection that went to something that resembled a PCV valve, however, thisPCV looking thing connected to the valve cover did not want to be removed. It was all I could do to twist it with a pair of channel lock pliers. The front valve cover also has a plastic tub running to it with a rubber connection to the same port looking thing that is on the rear valve cover on the left side of the engine.
My question is"where is the PCV?" If this thing on the rear valve cover is it, how do I remove it?
Thanks.
Old 02-29-2008, 10:56 AM
Default RE: Maintenance Problem
Slowroll, do you have any suggestions? Thanks.
Old 02-29-2008, 08:27 PM
PCV valve is a fixed orfice design, it doesnt rattle. Located in rear valve cover on passenger side. It's not normally serviced, "dirty air" tube going to it is designed to be cleaned or replaced.
Old 03-03-2008, 12:16 PM
Thanks, I knew you would have the answer.
09-11-2014 12:29 AM
Mrs.Buttersworth
09-16-2009 04:50 PM
ballpehler33
10-23-2007 01:32 PM
eechapa
09-05-2007 09:36 PM
Quick Reply: Maintenance Problem
