Low Oil Pressure - Cadillac Forum - Enthusiast forums for Cadillac Owners
Old 07-09-2008, 03:28 PM
Joe Joe is offline
Default Low Oil Pressure
My 1995 eldorado sometimes says low oil pressure when i come to a stop, my brother works at a shop and has looked at it and cant find a reason for it saying it, can anyone tell me why my car does this(it only happens once in awhile and typicailly happens when im stopped)
Old 07-09-2008, 07:23 PM
Default RE: Low Oil Pressure
have the oil changed with a new filter,I have had a clogged oil filter lower oil pressure maybe its the problem!!I had a 95 eldorado ,it leaked oil but never did the light come on
Old 07-09-2008, 07:25 PM
The normals low oil level, bad sender, worn bearings. Other possibles balancer bolt not torqued to spec.(no key way for oil pump, depends on bolt forcing balancer against oil pump gear and primary timing gear on crank) pump pressure relief valve getting hung open by foreign material. Check with mechanical gauge.
Old 07-09-2008, 07:48 PM
JBM JBM is offline
Does the light come on while you are stopping or when you have stopped and the engine is idling?
For 1. Low oil level, oil moves away from pickup in sump.
For 2. Idle speed is too slow to pump oil at normal pressure.
James
Old 07-09-2008, 11:04 PM
Katzmans Caddy's Avatar
I was leaning towards idle too low as well. You can also try a slightly heavier weight oil.
Old 07-10-2008, 01:48 AM
the simple question ...
how many miles on that engine?
Old 07-10-2008, 03:26 PM
Had that issue at a hot engine idle and it was a cheap brand oil filter. Try DELCO next time. This is assuming that your brother did check pressure with a mechanical oil gauge.
Old 07-10-2008, 09:14 PM
Excellent point on cheap white box and no name parts. Same goes for oil used. Some of these $19.99 oil changes are using oil that is thinner than cooking oil. Name brands only way to go with oil and filter.
Old 07-10-2008, 10:02 PM
Most name brand oil filters have some sort of check valve to hold oil pressure, unlike a generic white box one.
'97 Deville overheating/low oil pressure? hccaddie1 General Tech 6 10-10-2007 09:59 AM
1995 Sedan Deville: Stop Engine -- Low Oil Pressure [email protected] Cadillac Deville 2 11-08-2006 09:07 PM
low oil pressure at 1524miles? 2007escaladeEXT Cadillac EXT 5 09-26-2006 11:30 PM
Overheat and low oil pressure Jellobiafra Cadillac Deville 0 07-05-2006 11:41 PM
94 DeVille Low Oil Pressure sandawgcaddy General Tech 0 12-02-2004 08:39 PM
Tags
93, 94, allante, caddy, cadillac, engine, idle, l05, low, message, oil, pressure, pump, stop, stopped
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
