Help!!!Radiator Fluid in the transmission
Old 06-06-2007, 11:14 AM
cleven's Avatar
Default Help!!!Radiator Fluid in the transmission
Just as it says. I took the transmission out today to have it look at by a buddy that work at the local transmission shop. But one thing i wanna know is how the hell did this happen?I looked at a few caddys around the same year as mine and both of the tranny lines are not in the Radiator like mine where. None of theme run to the trans cooler in the front. And the other thing i wanna know is that can irun the transmission lines to a heavy duty transcooler for temp use if my Radiator is shot, i dont have the $200+ fora new Radiator as of right now and my father said the car has to be moved this weekend.
Old 06-06-2007, 03:09 PM
Default RE: Help!!!Radiator Fluid in the transmission
year, model, engine, etc ?
something here makes no sense to me,.
to get it moved, do whatever it takes including bypassing intake/outgoing hoses to the trani.
but dont take a trip to the Indy raceway until you do the right things.
it should do fine for an easy going drive.
Old 06-06-2007, 04:16 PM
FLCaddytech's Avatar
You can bypass the radiator and use an aux cooler.
You will need to seal off the trans cool portion of the radiator if it has been leaking internally.
Old 06-07-2007, 07:50 PM
cleven's Avatar
Ok got the trans back today. Its all good and what not. Just got it back in along with new axels. So the Trans cooler in front of the car isent good enuf huh. O well ill just spend about $50 on one and another 20 on a fan for it. Thanks for your help FLCaddytech
bubbapuma
Automatic Transmissions
06-14-2014 09:36 PM
paparoach
11-13-2012 03:11 AM
03-24-2009 08:22 AM
1989 fleetwood
24
11-21-2008 01:55 PM
Charlie
02-22-2007 10:33 PM
Quick Reply: Help!!!Radiator Fluid in the transmission
