Charging A/C. compressor reset - Cadillac Forum - Enthusiast forums for Cadillac Owners
Old 08-21-2008, 02:22 PM
Default Charging A/C. compressor reset
1995 Eldorado. Dash reads "refrigerant low. Compressor off". I bought some R134a. How do I get the compressor to come on so I can refill the system? Do I just reset the codes, or saw somewhere that said to use a jumper on the low pressure switch? If that is so, where is it and how do you do it?
Old 08-21-2008, 07:27 PM
Default RE: Charging A/C. compressor reset
Should explain on the under hood decal. If not, erase codes and recharge. I presume you have gauges to do this properly. The message can come on if its down as little as a 1/4 LB. And wheres the leak?? unless you want to do this job twice.
Old 08-22-2008, 12:20 PM
My guess is the leak is small. Compressor was serviced 8 years ago so still on charge from then. Have the proper guages. figured I would use the refrigerant that has "stop leak" in it to get it by for awhile. Probably won't own the car too much longer so want to get by. But my guess is even if I clear the codes, the second I turn on the AC the sensor will signal the computer to shut it down before I get time to get the refrigerant in it. So there probably is a need to bypass the sensor.
Old 08-22-2008, 03:26 PM
Add a little freon before starting car.
Reset of AUTO/ECON after R134 add themoonandthestars General Tech 1 09-14-2007 12:10 AM
'90 Seville STS Oil Reset mix4 General Tech 4 08-02-2007 03:31 PM
P0603 - Control Module Long Term Memory Reset green hornet 97 Cadillac Deville 1 04-21-2007 06:35 AM
Information center reset? Help 95eldoradoetc Cadillac Eldorado 0 09-14-2006 08:08 PM
reset air pressure read on dash kingofdagodz Cadillac Deville 0 04-21-2006 01:28 PM
Tags
08, 1995, ac, allante, cadilac, cadillac, charging, compressor, eldorado, light, low, recharging, reset, sls, system
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
