91 eldo heat issues
Old 12-06-2008, 03:28 PM
1991EldoTC's Avatar
Default 91 eldo heat issues
My 91 eldo heat has what I think are two seperate problems. Help me decide. The temp buttons docontrol the amount of heat or turns on the a/c if it is required. The blower motor however seems to be too slow. It is working but it does not seem up to what I would expect. Have these motors been prone to slow down while still working? I have some shop time today and should be able to start with a voltage check at the motor as well as a direct jumper to it to see if it will take off. Next I'll pull it to make sure there is no restriction like a mouse nest or anything else. Fortunately it is an easy replacement accessable on the firewall so if need be I'll get a new one. The other thing I noticed and am clueless on is the blending of upper windshield and lower compartment air. There is a noticable difference in the temperatures of the two air supplies. The upper is much hotter. Is that normal or if the blower was working harder would the hotter air be forced downward? It is slow enough that I think the hotter air is naturally rising rather than being forced out through the bottom. Where or what do I look for here. Is there a blend door I could check? I am waiting for my Cadillac manual which is on the way but I could use somedirection early. Thanks
Old 12-06-2008, 05:49 PM
Default RE: 91 eldo heat issues
Blend door behind glove box. A/C can set codes so I would check for them.
Hallock53
04-23-2016 04:25 PM
6pucker
04-25-2011 09:16 PM
abaines12345
06-08-2008 11:02 PM
BelgianTim
03-06-2008 02:24 PM
mustno1
09-05-2006 04:35 AM
Quick Reply: 91 eldo heat issues
