2000 ESC Climate Control
Old 02-09-2007, 11:22 PM
2000ESC's Avatar
Default 2000 ESC Climate Control
My 2000 ESC climate control system is putting hot air out of the driver's side vents and cold air out of the passenger side vents. It makes no difference if the system is in "Auto" or "Manual". When I change the temperature setting, it does change the output temperatures but this "split" is still present. Cycling the passenger side controls also has no effect.
Any ideas as to what may be causing this problem?
Old 05-11-2007, 03:51 AM
Default RE: 2000 ESC Climate Control
same thing happen to me and i took out the glove box and i found that the mechanism controlling the vent had malfuctioned . and theres like a lil metal control arm that attached to it that opens or closes to control the air mixture
Old 05-31-2008, 07:21 PM
justtalkin's Avatar
Thanks for your time. I was wondering what your outcome was. I have a similiar situation on my 1996 Seville. By manually disconnecting the air mixture door from the motor control, I have corrected the problem...so, I figure the motor control is defective. I would appreciate your feedback. Thanks.
proud american rider
10-03-2011 05:27 AM
Xball23
09-30-2010 11:45 PM
grock
08-26-2008 12:26 AM
spinkxxx1
01-03-2008 10:57 PM
bikr
10-03-2006 10:24 PM
Quick Reply: 2000 ESC Climate Control
