1994 eldo heater blower
Old 12-05-2008, 08:08 PM
musique's Avatar
Default RE: 1994 eldo heater blower
another good suggestion is turn off the blower in the cabin when it's below zero and allow yourwater temp toheat up a bit before turning it on. It's just a guess but my intuition says they don't like running full power when they're very cold.
  #12
Old 12-06-2008, 02:58 PM
carnut's Avatar
Cadillacs do that automatically!! Assuming the auto mode is used, the fan delays till approx 150 F coolant temp, then turns on to warm the car. There is no delay when the interior is warm like in the summer.
  #13
Old 12-29-2008, 09:05 PM
i have the same prob with my 92 eldorado . i replaced the blower motor but still cant get the new one to start,what can be the prob???????????????????????????
  #14
Old 12-29-2008, 09:15 PM
can you tell me where on the firewall the blower module is located thank you
  #15
Old 12-30-2008, 11:41 AM
carnut's Avatar
Under hood towards passenger side, sometimes under a black plastic cover. 2 wiring connectors to it.
  #16
Old 12-30-2008, 04:10 PM
thank you,i replaced the blower module and now the fan runs great,the fan sounds good but the air flow is very weak,back blower the air flow is great,but i put the front to defrost and i can barely feel the air flow.both heater core lines feel hot,and i removed the glove box everything seems good under there,i dont get any air flow at all from the vents but i get a little from the defrost cycle,hope you can help its cold here in canada
  #17
Old 12-30-2008, 07:58 PM
cadillacdave's Avatar
I had a NICE triple black roadster (sim con) eldorado , sunroof , vogue kit ,undoubtedly one of the sharpest cadillacs I have had ,and I have had over 60 in my lifetime,BUTthat norstar ,which was an excellent performer ,leaks,starters that are under the intake etc. THE FINAL STRAW was the BLOWER MOTOR you guys talk about!!!!!!the parts are CRAZY $$$$,s my 79 biarritz blower went bad last summer 29.99- I put it in myself!!!
  #18
Old 12-30-2008, 11:31 PM
the blower motor for my eldorado was 30 dollars canadian,i put it in myself,not a big job,but i have very little air flow
  #19
Old 12-31-2008, 02:03 PM
i just replaced the heater motor and the blower module in my 1992 eldorado,the blower is now workin fine but i have very little air flow on defrost and no air flow through the vents,does anyone know what may be causing this,please help freezing in canada
  #20
Old 12-31-2008, 08:13 PM
Vacuum leak, programmer, or actuator. Where will out when commanded?
86milkdeville
02-13-2018 08:21 PM
James1984
04-04-2008 08:12 PM
l306x
06-16-2007 06:08 AM
repo
10-20-2006 02:32 PM
Nick
11-20-2005 03:39 PM
Quick Reply: 1994 eldo heater blower
