1994 eldo heater blower
Old 11-10-2008, 03:37 PM
tmac57's Avatar
Default 1994 eldo heater blower
i have a 1994 eldorado, the heater won't blow and it is getting coldddd here in nh. my dash shows that it is on high, low, whatever but nothing comes out! i am a dumb girl, with a car she doesn't want to get rid of. but i NEED heat. help please!!
Old 11-10-2008, 03:43 PM
Default RE: 1994 eldo heater blower
have you checked fuses? does the car have any other issues? do you feel anything coming out of the vents, any heat?
Old 11-10-2008, 03:49 PM
tmac57's Avatar
the car has no other issues other than it is in need of brakes which i will do if i can get the heat working
tmac57's Avatar
fuses all seem fine so i am told
Old 11-10-2008, 04:06 PM
tmac57's Avatar
also the blower into the rear seats blows but only heat for a short while.............
Old 11-10-2008, 04:24 PM
well..... from all the information that you have givin the Forum..... it sounds like you have a bad blower motor......
do you have a friend that can check current going to the blower?
Old 11-11-2008, 01:24 AM
I am her son and know some about cars but not cadillac's haha.... where should i start to check to see if the blower motor is bad?
Old 12-01-2008, 06:53 PM
musique's Avatar
if it was me I would just replace the motor, it's somewhat common. I have a '90 Seville, and had a '97 eldorado and had to replace the blower motors in both cars. Sadly, for the ;97 Eldorado, the blower motor itself is $ 500.00 and it's a bit of a job having it changed.
Old 12-03-2008, 12:37 PM
carnut's Avatar
This car has a blower power module located underhood at the firewall. If that goes electrically open, it will not ground the blower motor to turn it on. You can run a jumper wire from the battery to the blower motor to verifythe blower motorworks prior to replacement.
Old 12-04-2008, 07:55 AM
I had a 94 and the blower motor went out on it. If everything else works simply check to see if the blower is turning on. If it isn't turn on the heat then check for voltage at the connector for the fan with a multimeter. You can get new ones for relatively reasonable prices online. They are simple to replace for the mechanically inclined. You would be wise to have a service manual but don't get locked into following it exactly. The official Cadillac Service Manual says to drop the engine. I have replaced four of these blowers by removing the coil pack from the engine to give me some room to work.
Quick Reply: 1994 eldo heater blower
