Door panel removal
Old 12-31-2008, 09:29 AM
rbargiel's Avatar
Default Door panel removal
I was wondering if someone can help me remove the driver side
door panel on my 98 Eldorado?
Thanks
Ray
Old 12-31-2008, 06:49 PM
Default RE: Door panel removal
This post may help
https://www.cadillacforum.com/m_12566/tm.htm
Old 01-02-2009, 03:55 PM
Take a small screwdriver & gently pry the plastic trim off form the door handle.Then take a flat head screwdriver & pry up the rearof thewindow control panel.When it starts to lift up you'll see the metal lock tab on the rear of the panel.Push in on the tab & lift up.Remove the phillips head screw underneath.Take small screwdiver & gently pry out on the upper rear corner of the carpet trim on the door.Make sure you've got the screwdriver deep enough as not to seperate the carpet from the backing.It will fold out when you've pried the corner out.Behind the carpet is a small hole,there's a phillips head in there.Remove the screw & the liftup on the door panel & remove.
rudedude_2k
09-19-2008 04:51 PM
toolmaker
09-16-2008 08:20 PM
Model 12
07-09-2007 05:24 PM
EastBayCaddy
11-05-2006 02:31 PM
bmw1023i
10-13-2006 08:22 PM
Quick Reply: Door panel removal
