is this normal on the caddy - Stabilitrac service stability system SYS
Old 07-30-2011, 06:57 AM
qboy7's Avatar
Default is this normal on the caddy - Stabilitrac service stability system SYS
a new message just showed up on the message center saying( service stability system SYS) is this normal ? or something has broke ? and is there away to clear the message from computer
Old 07-30-2011, 12:51 PM
92_Daddylac's Avatar
this usually is something you want to have looked at since the suspension is electronically controlled. There may be a sensor that has failed triggering this message.
Old 08-01-2011, 09:59 AM
I would agree with 92_Daddylac. The Service Stabilitrac message would mean that you need work done on this system to keep your vehicle in tip top shape. I hope that helps to answer what the message entails.
Jeff Morris, Cadillac Customer Service
Old 08-01-2011, 09:19 PM
gmtechs's Avatar
pull the code
qboy7
07-25-2011 09:07 PM
EDWEG
08-12-2010 11:58 AM
cadijac
03-28-2008 07:52 AM
08-27-2007 01:22 PM
Quick Reply: is this normal on the caddy - Stabilitrac service stability system SYS
