how change the engine coolant on the NorthStar
Old 12-19-2007, 02:32 PM
cesully's Avatar
Default how change the engine coolant on the NorthStar
Hi Folks,
I bought a 2004 DTS (blk/blk)about a month ago with approx 60K miles on it. Reading around this post I want to change the engine coolant asap.
Can someone forward me or point me in the direction to the specific proceedure to accomplish this task? I didn't have any luck in FAQ regarding the step by step process.
ALSO, the heater/A/C fan will not operate- sometimes the climate control will kick on if I go over a bump or accellerate aggressively- indicating it might be a bad connection somewhere. Possibly a blower motor connector? Where can I find this connection.
Thanks for any assistance and providing an invaluable source of information on all Caddys
Thx
Sully
Old 12-19-2007, 08:02 PM
Default RE: how change the engine coolant on the NorthStar
Flushing cooling system - Drain old coolant, refill with coolant, monitor level till cooling fan comes on and goes off 2 times. Re-install cap drive 2-3 miles and park. Recheck coolant level add as necessary.
Blower - check for codes, blower is under right side of dash.
Old 12-20-2007, 09:34 AM
not to over-ride the master, slowroll, are we suggesting dex-cool, distilled water, or pellets/ additives for this guy? maybe none is needed due to the miles on the car..... just a suggestion.......
cescully, big welcome to the Forum..... keep us posted on your coolant change.... good luck
Old 12-20-2007, 10:22 AM
cesully's Avatar
gotcha... just wondering if the bottom radiator hose is the best method... and should I be forcing the remaining old coolant out by some type of water pressure, say from a garden hose?
thx
Sully
and thx for the warn welcome guys...
Old 12-20-2007, 01:14 PM
scully, if i remember correctly a simple drain is good enough, see my post on the same, somewhere (i'll look up and get back).
rick
distilled, and green stuff.... water, and dex sts section, page 5
this will help. these guys are a wealth of info..........
rick
Old 12-21-2007, 09:49 AM
cesully's Avatar
thanks much rickyd...
I'm shooting for the old "an ounce of prevention saves a few hundred pounds of aluminum"...
well you get it...
I don't think this car's coolant was changed sincenew and it just hit 60K mls...
see ya!
Kucharz
Aluminum Block V8s
34
02-23-2015 01:49 PM
Will Hawk
Aluminum Block V8s
05-04-2010 12:44 PM
cady97dev
Aluminum Block V8s
03-20-2009 08:10 AM
SoulRebel
11-09-2007 04:34 AM
Quick Reply: how change the engine coolant on the NorthStar
