A/C in reverse
Old 09-08-2007, 02:36 AM
derrickwi's Avatar
Default A/C in reverse
I have a 2000 DTS. A/C works fine when outside temperature is mid 80 and below. Above mid 80 and 90 degrees outside A/C blows hot air through all vents. Any ideas? Thanks Guys.
Old 09-08-2007, 02:32 PM
Default RE: A/C in reverse
ORIGINAL: derrickwi
sounds like a sensor is shutting system down.
low refrig?
engine running to hot?
Old 09-08-2007, 03:56 PM
derrickwi's Avatar
Thanks. Engine doesnt read hot.
Even at moderate temps left side is blowing a little warmer than right. Swapped over temp sensors left and right. No difference. I am beginning to think its the instrument panel module. I get a code B0429 but thats the rear hvac dooractuator. Again manual points toIPM. I think thats a dealer replacement isntit because the manual says it has to be calibrated
Thanks again.
Old 09-08-2007, 03:57 PM
derrickwi's Avatar
Alsos checked refrig. Thats OK
parlain44
Automatic Transmissions
01-22-2009 12:58 PM
Irocz11389
07-07-2008 10:16 PM
Deville86
05-10-2008 07:38 PM
CaddyTrav
12-14-2007 07:41 PM
macalde32
01-07-2006 06:04 PM
Quick Reply: A/C in reverse
