Blower Motor Not Working
#11
Going through flow chart it should. You want to verify power and ground to control. There is a white label on spare cover with 3 digit codes. You should see either CJ2 or CJ4. from your description I believe you should see CJ2. Chart doesn't doesn't really change CJ4 has a relay that CJ2 doesn't use.
#12
CJ2. I have to pull the dash panel again to test for continuity. Just to make sure I got it right if there is no breaks in the line I should have continuity between gray w\pink on the controller side and gray w\blue on the resistor side.
#15
Connector X202 is where wire changes colors. It has 16 pins I would look there. Location as described in service info. X204 is 8 pin connector
I/P harness to the HVAC harness, under the right side of the I/P to the left of the blower motor next to X204
#16
So it turns out in my opinion it's bad design, the connector is attached to the HVAC ductwork and apparently the duck work has a leak causing it to drip onto connector 202 and caused quite a bit of corrosion. Cleaned up the corrosion and everything is back to 100%. Thanks for all your help I couldn't do it without you!
