2008 DTS AC Relay hot.
Old 04-28-2014, 03:34 PM
marz627's Avatar
Default 2008 DTS AC Relay hot.
My A/C wouldn't come on today so I checked the fuses and relays associated with that system. One of the relays, an 8034 was extremely hot. I removed it and switched it with a relay (same number) from another one on the fuse box and the A/C compressor kicked on and it worked. I drove to the store, working fine but when I came out and started the car the A/C compressor would not kick on again. I swapped relays and it engaged. Anyone have any ideas what might be going on here? Thanks
Old 04-28-2014, 05:41 PM
A/C compressor clutch cycling too much, causing relay coil to overheat. Corrosion on terminals causing increased current draw again overheating coil. You could try" New" relay it's possible relay was updated.
GreggB
08-05-2014 12:16 PM
08-15-2012 04:31 PM
Mags1
11-19-2010 07:37 PM
Tyrannous
02-05-2007 09:09 PM
Quick Reply: 2008 DTS AC Relay hot.
