2000 cadi dts misfire
Old 06-14-2011, 12:30 AM
marlow.bailey@gmail.com's Avatar
Default 2000 cadi dts misfire
couple of days ago i notice my dts idling very hard........ and i could sometimes smell gas...today the engine light came on and flashed..... so i Google the issue and found it was a random misreading and suggested to change the coil pack. however there is a found and rear coil.. how can i find out which cylinder is misfiring so that i can changed the correct coil pack.. or should i just change both to be on the safe said... has anyone had to do this. please share you thoughts..
Thanks
Old 06-14-2011, 08:54 PM
gmtechs's Avatar
u need to get the vehicle scan and figure out which cylinder is missing
then u need to check the plug and wire to make sure they r working
06-27-2023 12:22 PM
Xball23
09-30-2010 11:45 PM
farmjazz
Aluminum Block V8s
09-15-2008 08:33 PM
summitgirl
06-30-2008 08:40 PM
summitgirl
06-28-2008 12:01 AM
Quick Reply: 2000 cadi dts misfire
