Window rolls down just not up
Today my drivers side frontwindow quit rolling up in my 99 deville. What is the process for getting the interior panel off without destroying it and which is it most likely to be the switch or the lift motor.
RE: Window rolls down just not up
It'll probably go ahead and roll up if you keep messing with the switch. Our 88 Deville does the same thing. We just keep trying the switch and iteventually works. (2 windows and can't replace right now.) Just as a side note, a 96 Olds 98 that we were considering buying recently did the same exact thing. A GM problem maybe?
i have the same problem with my 2000 deville...on mine the whole regulator had to be changed....they said the part that attaches to the cable to bring the window up is made up of plastic..well over time the plactic broke hense window falls down and wont go up
ORIGINAL: gayeg
it happens to all cars after a few years, depends on how often it is used, heat to the doors, moisture,
door slamming, debri, etc., etc...
i got cars that do it every 3 to 5 years, i got one that is 19 yrs old and still going.
WILDCARDRACER1@YAHOO
08-12-2007 02:08 PM
