Window regulator problem - 2001 Deville
Old 08-23-2010, 07:19 PM
khdaniel's Avatar
Default Window regulator problem - 2001 Deville
I have read the great posts on how to replace the window regulator in this forum and they were a great help. It was very straight forward until I tried to remove the window retaining clamps on the window regulator.
The problem is I can not reach the nuts on window retaining clamps because the motor and/or regulator is frozen in place. I can only lift the glass by hand about 5 inches above the bottom of the window frame in the door. At this point the cable on the bottom of the regulator tightens up preventing the window from being raised. The window will not operate with the motor and switch.
I appears my only option at this point is to cut the bottom cable to allow me to raise the window completely so I can loosen the glass retaining clips and then remove the regulator. I was hoping to get the regulator out of the door intact so I might have a chance to repair it, but if I cut the cable, that option may be gone.
Is there a way to free the motor and regulator cables without cutting a cable?
Any suggestions from the experienced posters on this board will be greatly appreciated.
Thanks!
blackdevilledts
05-13-2009 07:55 AM
seviller
08-23-2007 06:31 PM
Davids DTS
07-31-2007 09:06 AM
latinowarrior
08-19-2006 08:23 PM
transtechterry
02-24-2006 12:37 AM
Quick Reply: Window regulator problem - 2001 Deville
