White smoke from tailpipes. Help!?
Old 04-18-2017, 03:05 PM
Newtocadi's Avatar
Default White smoke from tailpipes. Help!?
Hey everyone I'm new to cadillac & to the cadillac forum. I bought a 2002 Cadillac Deville about a year ago. Truly amazing car! It now has 111k miles on it. I put a new transmission in it and a new radiator as well. About a week ago, I had a mechanic check the car since it was leaking coolant. He said it was the hose so he changed it, it had a tear in it, but now it seems like it is leaking more. Also I noticed that there is this semi thick white smoke coming out from the tailpipes. It smells fruity, burnt, & it has a maple smell to it too. Anyone know what it might be or any recommendations? Thank you in advance.
Old 04-18-2017, 08:34 PM
Blown head gasket. Have your mechanic perform a CO test on cooling system to be sure.
Old 04-18-2017, 10:45 PM
Newtocadi's Avatar
ok will do. Ima take it tomorrow morning. As far as driving it around, can I or is it not recommended?
Old 04-19-2017, 11:03 AM
not really advised, but check coolant before driving. and watch engine temp on DIC while driving stop if it hit 240 and let it cool.
Old 04-19-2017, 12:57 PM
Newtocadi's Avatar
mechanic said he was going to do a block test on it. Is that better than the CO test? He said he'll let me know what he finds out.
Old 04-19-2017, 08:56 PM
So Long's Avatar
A block test and a CO test are the same. The test determines the presence of exhaust gasses in the coolant.
Old 04-20-2017, 10:16 AM
Newtocadi's Avatar
so the mechanic said it failed the block test. Seems like he didn't want to the job since it's a "very big job." Told me I have 3 options: get new engine, get a used engine, or fix that one. Car does not overheat but does lose coolant. I check it every time I drive. Been seeing that used/reconstructed engines range from 700-1200 while a new ones range from 1500 and up. Any recommendations? Quick alternatives to help eliminate the smoke?
Old 04-20-2017, 01:08 PM
head gaskets are a big and expensive job. How attached to this car are you? Used engine depending how its guarantied could be a good option. There are some "miracle in a can " products out there, which could temporally correct smoking. I'm not a fan of them. To me they are merely to patch it up long enough to trade in.
gmanney
02-18-2010 01:52 PM
97devillenmd
12-06-2009 09:18 AM
dimitri94seville
12-27-2008 06:24 PM
Caddi06
08-02-2008 08:33 PM
bighank
03-04-2008 10:43 PM
Quick Reply: White smoke from tailpipes. Help!?
