turn signal
Old 05-09-2008, 08:30 PM
18165p's Avatar
Default turn signal
1996 turn signals do not work but em flashers do is there relay to replace and where. it is deville
Old 05-10-2008, 01:31 AM
Default RE: turn signal
You say that the turn signals don't work, but do you mean that they don't light at all, or do they light but stay on and not flash? If they come on but don't 'flash' it could be the flasher,since there are 2 of them. 1 for the turn signals and 1 for the 'hazard' lights. If they don't come on at all , it could be a fuse since they both have their own fuses. I believe the
'hazard' light fuse is in the engine compartment fuse panel, and the turn signal fuse is in the
trunk fuse panel, and the flashers should be located somewhere near the steering column, but you will have to remove the trim panel under the column to find them. I am just basing this
on the location(s) on my 97 Eldo. If it is different onthe 96 Deville, than hopefully someone
else will correct me on this. Hope this helps.
Greg in NWA AR
08-22-2014 03:43 PM
green hornet 97
10-08-2012 09:38 PM
daniel0015
07-10-2006 08:08 PM
prob aller6968
07-03-2006 08:51 PM
blackcaddy99
03-28-2006 09:03 PM
Quick Reply: turn signal
