Running a 12v constant for radio
I need to run a 12v constant power to my radio. The factory memory wire is affected by the power saving feature, and after installing the proper radio harness (gmrc-o3) the only problem i have now is the radio does not remember anything after the power saving thing kicks in after about 15 min. Does anyone know of a good place to run a wire to?
96 Deville
4.6 northstar
non-bose
non-amplified
I hope i didnt forget to mention anything
Thanks for any help
96 Deville
4.6 northstar
non-bose
non-amplified
Thanks for any help
RE: Running a 12v constant for radio
Just the deck in the dash, thanks for replying but I allready ran one through the firewall and to the battery. Everything seems to be working fine, so far.
ohh, and I put in a 4A fuse just to be one the safe side
Same issue.
I have the same problem as you. I read that their is a 12v pink constant in the steering column,but I'm not messing around in there. What gauge of wire did you use and was 4amp fuse sufficient?
