power window trouble
i have a 97 sedan deville and my passenger side power window only rolls down i have power to both sides of the switch and motor so i figured motor was bad i replaced it still same problem is there a relay or module that controls that
first of all
what works
does the driver side go up and down
does the back seat go up and down
if so can u control the passenger side to go up and down from the passenger switch
i am sure its a switch problem u r having
if it goes down it should go up
the switch just reverse the power and ground to change the direction of the motor
what works
there is no ground to say its a module that controls it
ok this is how it works say the driver window motor wires are dark blue and light blue
ok if u put 12volt to the dark blue and ground the light blue window goes up
if u put 12 volts to the light blue and ground to the dark blue it goes down
i am not sure these are the colours of the wires
bevlind@comcast.net
07-09-2007 03:59 PM
