Pcm p0300 misfire code
Old 11-24-2016, 09:48 AM
TOMMYDMECHANIC's Avatar
Default Pcm p0300 misfire code
Hello guys,
I need some help finding why my Cadillac Deville has a flashing ses light and also is misfiring.I have replaced all the spark plugs and both ignition coils front and back.Could a oxygen sensor cause this problem?Could this abs code cause this problem abs c1218?I would really appreciate any help about other things to check.The ses light only starts flashing when I got over 20 mph...when idling it does not flash...
Thanks
Old 11-25-2016, 05:18 PM
bhawk510's Avatar
Hope this helps:
Possible causes - Faulty spark plug (s) - Faulty ignition coil (s) - Clogged or faulty fuel injector (s) - Intake air leak - Fuel injectors harness is open or shorted - Fuel Injectors circuit poor electrical connection - Ignition coils harness is open or shorted - Ignition coils circuit poor electrical connection - Insufficient cylinders compression - Incorrect fuel pressure
Read more: P0300 Cadillac Cylinder Misfire Detected Random Cylinders OBDII Engine Light Trouble Code | Engine-Codes.com
STSteve02
10-04-2012 07:02 AM
Baldeeny
02-18-2012 10:59 PM
Zekeg
08-19-2011 02:51 AM
bsstyle2011
04-14-2011 12:48 PM
clemece09
12-21-2009 07:28 PM
Quick Reply: Pcm p0300 misfire code
