P0741 no SES light?
Old 05-19-2008, 09:47 PM
Ericn79's Avatar
Default P0741 no SES light?
I have a 99 deville with 75,000 miles on it and a few weeks ago my SES light came on because my gas cap wasnt on tight. I obviously put the gas cap on and reset the codes and the SES light went off just as it should have. I decided to pull the codes last night out of boredom i guess and found a P0741 code marked as history but it wasnt there when i checked the codes a few weeks ago. The SES light has not come back on since the gas cap incident so i am at a loss as to when the P0741 code occurred because i have not had any issues with the tranny. I am concerned because i have read in several places that this particular code is pretty serious but my car doesnt seem to display the symptoms of this code. Could this be a glitch or do i have a real here? I am also baffled by the fact that the SES light didnt come on when this code popped up.
Old 05-19-2008, 11:34 PM
Default RE: P0741 no SES light?
ORIGINAL: Ericn79
Codes remain on memory until you perform a CODE RESET.
you have to go through the menu commands to achieve that.
look in our FAQ for details
also check some of the others below
The BEST car Cadillac ever made is the .. you get to pick.
https://www.cadillacforum.com/m_9438/tm.htm
MY Cadillac has more miles than yours thread .. Lets get the 400,000 mile cars.
https://www.cadillacforum.com/m_12353/tm.htm
CODES .. Pulling & understanding CODES .. we need CODES to help you.
https://www.cadillacforum.com/m_18197/tm.htm
https://www.cadillacforum.com/m_17425/tm.htm
https://www.cadillacforum.com/m_11904/tm.htm
Community Services: Auto parts, Vehicle Taxes, highways cams, picture capture,
Corp 800 #’s, unique shipping services .. etc ... take a look.
https://www.cadillacforum.com/m_9880/tm.htm
Average age of our Cadillac owners .. where everyone says they are 23.
https://www.cadillacforum.com/m_931/tm.htm
Why you should change to coolant the day you buy the Cadillac.
https://www.cadillacforum.com/m_7193/tm.htm
https://www.cadillacforum.com/m_7388/tm.htm
Transmissions or Engines - why you do NOT FLUSH the 4100 & 4500 drive trains.
https://www.cadillacforum.com/m_6036/tm.htm
Cadillac GM e-ghosts electric problems, intermittent codes, etc.
https://www.cadillacforum.com/m_6068/tm.htm
Help from our TECHs ? You really want to read this.
Cadillac TECH FAQ MENU .. pull up all the FAQ topics
https://www.cadillacforum.com/m_6733/tm.htm
Cadillac Technical FAQ section .. everything Cadillac
https://www.cadillacforum.com/forumid_64/tt.htm
Cadillac Allante TECH FAQ .. things that the car needs often, owner’s manual, etc.
https://www.cadillacforum.com/forumid_83/tt.htm
The Cadillac Allante Pub - discuss, argue, and laugh .. Allante not needed to jump in.
https://www.cadillacforum.com/m_21055/tm.htm
Allantesource.com Allante PROCEDURES MENU .. issues that few know how to handle
https://www.cadillacforum.com/m_18287/tm.htm
Hobby Corner .. Hot wheels, trains, whatever ..
https://www.cadillacforum.com/forumid_60/tt.htm
Cadillac History .. The real McCoy, from day one.
https://www.cadillacforum.com/m_6356/tm.htm
Welcome to CadillacForuM.com
Old 05-20-2008, 10:31 AM
Ericn79's Avatar
so i read through the links you posted and found a way to test the TCC but it didnt explain it clearly enough for me to understand the results. I drove the car with the SES light off steady at 55mph and tapped the brake slightly and the RPM's went up slightly like it said it would. What wasnt clear was whether or not that was a good sign or a bad sign i am obviously hoping that means the TCC is actually working properly. Please let me know so i can relax a little bit because i am in no position to get this problem repaired at the costs i have seen so far..Thanks for all the help!
troubleb18a1
12-03-2011 08:44 AM
scaryeyes
10-11-2010 08:18 PM
2001_Seville_SLS
Automatic Transmissions
04-06-2010 06:08 PM
wilke_jb
05-07-2008 12:12 AM
Ericn79
03-21-2008 05:28 PM
Quick Reply: P0741 no SES light?
