Oil pan gasket change 97 deville - Cadillac Forum - Enthusiast forums for Cadillac Owners
Old 06-28-2008, 09:50 PM
Default Oil pan gasket change 97 deville
Okay i am going to get my oil pan gasket and front valve cover gasket changed this upcoming week. I was wondering if there was any tips that i should know about. I heard you have to remove the drive train to change the oil pan gasket is that true. Let me know if there is any other threads on this. Also this week my service engine soon light came on. The code i got was pcm p0122. Low voltage on throttle positioning sensor. Do you think i should change the throttle positioning sensor. It was running horribly when the SES light first came on. Hesitating at take off then it finally starting running right. The SES light is still on but no codes because ireset the codes.Thanks
Old 06-30-2008, 09:26 PM
Katzmans Caddy's Avatar
Default RE: Oil pan gasket change 97 deville
Quote:
ORIGINAL: dano2508
1. I heard you have to remove the drive train to change the oil pan gasket is that true. Let me know if there is any other threads on this.
2.Also this week my service engine soon light came on. The code i got was pcm p0122. Low voltage on throttle positioning sensor. Do you think i should change the throttle positioning sensor. It was running horribly when the SES light first came on. Hesitating at take off then it finally starting running right. The SES light is still on but no codes because ireset the codes.Thanks
1. True
2. SES should go off when codes cleared, try again. If car is runnning ok now I'd leave it alone for now.
Oil Pan Gasket Change on 1990 4,5 litre deVille DER MotorSports General Tech 0 01-20-2011 04:50 PM
472 no oil pressure after oil change? hl8a Big Block V8s 1 09-08-2008 06:18 PM
leaky oil pan 98 deville (Updated with fix Results) ExBailbonds General Tech 4 12-01-2007 09:33 PM
Oil Change & Filter Change SoulRebel Cadillac V Series 3 11-09-2007 04:34 AM
93 deville oil pan removal? HELP cadworks Cadillac Deville 1 10-31-2007 05:56 PM
Tags
1998, 97, 99, cadillac, cadlac, change, changing, deville, gasket, gaskets, ld8, northstar, oil, pan, removal, removing
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
