Oil Change Intervals
Hey Guys, what do you think?
Should the oil be changed every 3000 milesor 3 months like you would any other vehicle or should I change by the Oil Life Gauge on my Caddy? I have put just over 3000 miles, with about 2 weeks left on the 3 mo interval. However, my oil life is at 45%. I usually change every 3000 miles as I always use the miles before the 3 months is up. Just curious as to what you guys usually do.
RE: Oil Change Intervals
ORIGINAL: Tarrance
https://www.cadillacforum.com/m_5792/tm.htm
The reminder is just that in my opinion. If you read all of those post which wll take about an hour (hee hee) you will see many opinions.
I use the reminder to change my oil and try not to let it get below 15-20% before I do BUT there is absolutely no harms for you to go by the 3 month rule unless of course if the reminder comes on before 3 months. I would say you`d probably be better off changing early vs. the reminder.
chester_007
03-07-2011 05:44 AM
