need help
need help
i am replacing the head gaskets in my 02 deville. i need to know the best way to hold my cams in place when removing the head. i know they are under pressure, so just any advice on the best way to do it would be appreciated
They should not move that much for it to be a big deal. Make sure pistons are down in the hole 3/8" of an inch before you put head on should be enough to keep valves from hitting piston. The timing chain installation is somewhat unique. You definitely want service information to reassemble.
cadillactt
03-12-2008 01:31 AM
