low coolant message on display - Cadillac Forum - Enthusiast forums for Cadillac Owners
Old 08-20-2007, 08:52 PM
Default low coolant message on display
i think it may be the sensor but i am unable to locate it.i have not a clue where it is.i checked the coolant reservoir,not there.looked at the radiator,can not see it but with all the covers its hard to see anything.any help would be great.just a general location to look?thanks in advance for the help.see ya, Bill
Old 08-20-2007, 09:08 PM
Default RE: low coolant message on display
Bill,
I thinksomeoneposted a similar probablyrecently. I'm not sure if it was this cadillac forum or not though?
They stated the sensor was in the coolant reservoir, but it turns out the problem was the connector tothe coolant reservoir was broken.
Hopefully the pros will chime in.
What year andmodel do you have?
-jasper
Old 08-20-2007, 09:29 PM
Jasper,it is a 2000.i checked the reservoir over and under and did not see it,not saying i did not overlook it,but i will look again in the am.thanks for the reply and if anybody else has other views please reply,thanks again in advance,Bill
Old 08-21-2007, 10:10 AM
Katzmans Caddy's Avatar
Hate to state the obvious but did you top up the resovoir? I believe a level of anything over an inch below the filler base will trigger the message.
Old 08-21-2007, 10:12 AM
FYI. Here's the link to theproblemImentioned.
google search "I found my leak, now i need help"
-jasper
Old 08-21-2007, 07:44 PM
i did check the level very first thing and it was full.i rechecked the reservoir for the low coolant sensor but still can not find it in the reservoir.i'll keep looking.any help would be great.Jasper i will google the site you mentioned and see if that helps.thanks again for any and all suggestions.see ya' Bill
check coolant level display nobde Cadillac Deville 3 10-19-2011 10:10 AM
Engine Mangement light comes on when coolant is low but stays on sgraham General Tech 2 09-19-2009 10:58 PM
92 eldorado false hot coolant message sbsg2005 General Tech 0 04-30-2009 07:39 PM
Coolant Smell no Visible coolant or coolant in oil???? cady97dev Aluminum Block V8s 2 03-20-2009 09:10 AM
Display Message caddyfan1 General Tech 3 11-06-2007 10:17 PM
Tags
1999, caddy, cadillac, coolant, cts, deville, dts, found, help, i, leak, light, location, low, message, sensor
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
