97 oil proublem
Old 08-20-2007, 06:51 PM
33 boggers's Avatar
Default 97 oil proublem
Hi nube here. I have a 97 sedan deville, I just noticed that when I stop at a light the low oil light comes on, when I get going it goes out. Oil on dip stick is ok. Could it just be a sending unit? Or the pump( I hope not) The motor is a gm crate installed in 02 by dealer. Thanks in advance for any help.
Old 08-21-2007, 09:16 AM
Katzmans Caddy's Avatar
Default RE: 97 oil proublem
Does yourengine falter at all, if so could be a low idle. If you give it some gas does the light go out? Also make sure you are reading the dipstick correctly. If it is one of those wire jobs with a plastic nub on the end they are hard to read.
Old 08-21-2007, 12:46 PM
33 boggers's Avatar
No falter at all, when I stop it comes on and when I get going it goes out. So I assume if I rev the engine it would go out. And I will recheck the didstick reading.
edgrmndz
02-19-2011 07:06 PM
td25
02-13-2011 07:11 PM
1989 fleetwood
09-11-2008 02:49 PM
hl8a
Big Block V8s
09-08-2008 06:18 PM
Quick Reply: 97 oil proublem
