Information Center Not Working in 1992 De Ville
Hi, the information center has quit working in my 1992 De Ville. I hope someone can help. The floowing insterments are effected.
Fuel Data Center, Fuel in tank. In addition the Electric Climent Control is not working that controls outside temp display, warmer/colder, defrosters, and air conditioner.
Note all of this stopped at the same time and one would think it's a fuse. So I checked all th fuses under the dash and all of the maxi fuses and they all "look good"
is there any other fuse I should check or could someone direct me to where I should look next?
Thanks for your help,
Ken
Ken
When I first start the engine, all the sections in both the FDC & ECC panels light up for just a second and then go out. But after this nothing.... and nothing works, no heat, no air, no display..
Thanks for your reply.
Ken
Ken
Thanks Slowroll, I pulled every fuse out and checked them with a meter. I checked every ground wire I could find. One thing is I don't know where the ground wire is for the dash area. Hmmm, I just may have to take it in. I'll let you know what they find. Hey thanks for your help and have a Merry Christmas!
Thanks Again,
Ken
Thanks Again,
Ken
Daddy....did you ever find the problem with your cadi???? I have the same with a 1991 .... checked all fuses....unpluged and plugged stuff.....no results....compressor comes on....no fan.... no data.....can not check codes because data centers will not light up.... need help....
Bj Gordon
03-25-2021 11:56 PM
caddygeorge
09-13-2006 07:20 PM
