Help diagnosing rough idle...
Old 01-25-2015, 11:50 AM
murondubs's Avatar
Default Help diagnosing rough idle...
I was gifted a 2003 Cadillac Deville, though it has some issues I am trying to address.
Currently it has a rough idle, it definitely feels like it is misfiring (almost like a "hiccup" within a couple of seconds of each other). Once I apply gas, it smooths out with no issues. I have cleaned the mass air flow sensor and replaced the spark plugs. But no luck. When I replaced the spark plugs, it had a smooth idle for about a day, then back to being a rough idle. At this point I am unsure of what step to take next. I have an Ignition Spark Tester, but seeing as I have to remove the entire ignition coil for the front 4 plugs at once, I am not sure if this is a safe way to test each terminal.
Can anyone help me figure out what to do next?
Thanks!
Old 02-01-2015, 11:17 PM
Katzmans Caddy's Avatar
Coil packs are expensive but that's the next step imo.
kaperoni
07-05-2008 12:59 PM
EViLLSeViLLe98
03-26-2008 04:44 AM
david999
02-06-2008 07:36 PM
sonotech
01-05-2008 07:05 PM
AKA19047
05-11-2006 10:36 PM
Quick Reply: Help diagnosing rough idle...
