GM Cadillac 2003 DTS - Won't shift out of park
Old 11-26-2007, 10:59 AM
Davids DTS's Avatar
Default GM Cadillac 2003 DTS - Won't shift out of park
Almost ended-up spending Thanksgiving in the parking lot of Taco Bell half way between GA and MI. Luckly I found the overide switch. Any ideas what I need to do to fix.
Moderator edit
Title
Old 11-26-2007, 06:41 PM
Default RE: Won't shift out of park
Brake Shift Interlock Solenoid isn't working. DTS should have floorshift, spilled drinks near or on shifter can cause linkage to stick and not work. If that is the case, if it's not real bad you can try to clean shifter assembly and it may work.
Old 12-02-2007, 10:51 AM
Davids DTS's Avatar
I took the trim plate off to expose the shifter. I don't see the solenoid it might be under the shift assembly I don't want to take that apart. I ended up using a zip tie to permantly engage the over ride. Not the best idea, but good for now.
DevilleDriver
Automatic Transmissions
13
09-06-2013 12:45 AM
katrinac
09-18-2010 06:35 PM
Triplellll
08-10-2010 08:17 PM
Bates
02-08-2008 06:55 PM
dschlieve
01-28-2007 05:31 PM
Quick Reply: GM Cadillac 2003 DTS - Won't shift out of park
