gas mileage
Old 11-07-2008, 11:28 PM
92deville's Avatar
Default gas mileage
a few months a ago my 92 deville was getting 24.8 MPG and over the last few months it has dropped to 21.6 MPG where it is now, i tried fuel injector cleaner and that did not help my mileage any. my driving style is the same and i have always put 93 octane gas in it? any suggestions on why and how could i get my mileage back to where it was? thanks
Old 11-07-2008, 11:37 PM
Katzmans Caddy's Avatar
Default RE: gas mileage
Air filter and tire pressure are two easy ones. Get a new filter and pump up the pressure. I keep mine at 40 psi, rocky ride but better mileage.
Old 11-08-2008, 12:08 AM
92deville's Avatar
its got an almost new air filter and my tire psi is 35 on all four, i'll try that thanks
Old 11-08-2008, 12:42 AM
What about plugs, how old are they? wires?
Old 11-08-2008, 01:12 AM
92deville's Avatar
not sure haven't changed them since i bought itjan 08
Old 11-08-2008, 10:01 AM
One year old, should be ok.
Old 11-08-2008, 10:38 AM
It may not hurt to check them and change if needed.
I just got my first Caddy, a '97 Deville D'elegance, at the end of September. Since I don't know the history, I've been going over things one by one. Like changing the oil even though it said there was 48% life left (did someone simply reset it without actually changing it?). On my first long highway trip with it it ran fine on the first leg but developed a strange "missing" on the return trip, which got worse over the following week (no SES). Most of my research indicated plugs and wires. So I bit the bullet and got them, and much to my surprise this engine is the easiest 8-cylinder I've ever changed plugs on! All they plugs looked about the same, minor deposits etc, but I found the #1 plug wire had a cut in it, down into the carbon. The "missing" is gone, runs a bit better than before.
I have not had my car that long, but after a trip to visit the grandkids a few weeks ago, the average MPG on the car (dash indicator) was 26.8. On paper it was 28 - even on a couple of tanks of 91 octane, which seems to be the best you can get in Kansas/Missouri area. It was the best 600+ mile one-way trip we have taken to date! This car replaced a '92 Olds 98 Touring Sedan with over 200K. Before developing severe electrical issues last year it would routinely achieve 30-32 with a supercharged 3800. I thought my T/S was comfortable (3 major back surgeries so far) and was a little upset when Oldsmobile went orphan, but I believe I found a suitable replacement.
Tom
Old 11-08-2008, 05:54 PM
92deville's Avatar
i will check them the first chance i get, i know the car was well maintained,thankstom and katzmans caddy
Old 11-09-2008, 01:15 PM
would a climate change, and driving habits of that change be the reason? is this a one time mpg check, or is it a constant reading now?
Old 11-09-2008, 07:40 PM
92deville's Avatar
its gotten colder here over the past few weeks, my driving habits are the same, the digital average MPG use to go from 24.8 to 25 and now it says anywhere from 21.5 to 21.8, currently still at 21.6
Quick Reply: gas mileage
