error code E30 need help
i was out crusin this last weekend got pulled over by the highpow lol and before i left i fugered might as well check the codes while i was stoped and E30 came up along with E28 i know that one allready could the E28 through the E30 or are they seperate probs thnx brick
RE: error code E30 need help
E30=Idle Speed Control Circuit Problem. Some switch is out of adjustment: TPS/Power Steering Sw/park or neutral safety sw. Out of adjustment minimum air rate, ISC/TPS can cause ISC not to control idle. E30 could also be a false code Long diagnostic 'tree' to follow.....
ORIGINAL: Dave S Texas
