engine idle to high
Old 11-13-2007, 01:17 PM
boogcaddy's Avatar
Default engine idle to high
i have a 95 deville 4.9 and the engine just wants to go it seems like, when im done driving and put it in park it revs too high,and sometimes when im driving ill stop at a stop light and it jus wants to go i will let go of the brake and it will idle all the way to 25 mph... what is going on???? please help
Old 11-13-2007, 06:56 PM
Default RE: engine idle to high
SES light on or off? Post E codes if present. Sound like idle need relearned.
Old 11-14-2007, 09:17 AM
boogcaddy's Avatar
thank you for the reply, there is no light on and no codes i have reset it and its the same but this same thing happened last winter and it stopped when it got warm out, now its cold and its doin it again..
Old 11-14-2007, 05:39 PM
Once codes are cleared and car does it thing if you check codes does E52 show up?, your problem could also by poor grounds at both sides of core support and where ground cable attaches to block near starter. An intermitent TPS could be sending incorrect values depending on how hot or cold it is. I would look at grounds first. relearn tps and idle. If your getting E52 ecm is losing power and resetting - idle is learn is lost, and your idle concern can re-occur.
Old 11-15-2007, 08:13 AM
boogcaddy's Avatar
thanks for your help,, well i changed the mass airflow sensor and it has stopped for now ,lets hope its all good
Old 08-11-2016, 10:24 AM
Anita Mae's Avatar
Could you tell me where the Mass Airflow sensor was located? And what does the sensor say on it?
Old 08-11-2016, 11:58 AM
1995 deVille doesn't have a Mass Air Flow sensor. Also this thread is almost 9 years old. You should have started a new thread with your concerns. MAF on your Fleetwood ,which is an entirely a different car, is silver and black mounts in hose attached to air filter cover.
Old 08-11-2016, 01:10 PM
Anita Mae's Avatar
Default SlowRoll
Oops!! Sorry. Was just reading through some posts trying to find an answer to my current question about the interior lights when I seen the post about high idling. We in fact had that issue with our 95 Deville, replaced the idling linkage which helped. But seems it is slowly trying to start doing it again.
Sorry.
Old 12-02-2016, 10:45 AM
Tammy Bruegman's Avatar
Hi I have a 1995 Deville. It has a loud vibration that seems to happen when I turn the defrost or heat fan on. When you look under the hood you can see a hose that appears to be hitting a fan causing the vibration. After driving it about 30 mins there was a warning light, engine overheating, and shut off. Ive checked the radiator and its ok. I get other messages also change engine oil, service air ride and add Coolant. It sat for about 10 mi s and started right up but the vibration was worse.
Old 12-03-2016, 04:32 PM
It sounds bad. I would have cooling system tested for CO engine may have blown head gasket. Engine shutting off may indicate overheating has caused internal damage requiring another engine. The vibration maybe one of the fan motors you could disconnect one at a time and see if anything changes.
xquizitone
03-22-2010 10:17 PM
teddykan
02-03-2009 06:40 PM
tigerdan
12-03-2008 02:26 PM
kobrien8
11-06-2008 01:39 PM
daviddonovan4
11-17-2007 02:23 AM
Quick Reply: engine idle to high
