deville window motor
RE: deville window motor
ive got a 96 concours so its not exactly the same, but should be same overall.
-first you pop off the little square of plastic behind the door handle. (you touch it everyday with the back of your hand).
-next take off the screws under that
-after you get that unscrewed take the whole plastic cover off of the door handle area. it'll take a little manueverin to get around the handle.
-after that you just have to unscrew the two or three scres that are in the plastic around the bottom of the door. should be one directly underneath, and one directly towards the rear of the car from the handle.
hope this helps. even though its not exact you should be able to figure your way out with that info. but just to let you know, theres a metal framing around the window motor and its not the easiest thing to get too. imagine a sheet of metal with a few big holes in it to try and fit your hand in to do all of the work... good luck
