Cooling system
Old 01-03-2007, 05:30 PM
misfit6794's Avatar
Default Cooling system
What is the normal running temperature range for a 96 deville?, nonconcours
Old 01-03-2007, 06:37 PM
Default RE: Cooling system
I assume you mean coolant temperature. I have a '97 so it should be the same. Mine runs between 196 degrees and 206 degrees.
Old 01-03-2007, 07:18 PM
FLCaddytech's Avatar
up to 220 is normal.
Getting much over 225 something is probably not right.
235 - 240 shut it off.
Old 01-03-2007, 08:41 PM
misfit6794's Avatar
Thank you. I just purchased a 96 deville with only 82,000 miles.I can smell coolant around the base of the windshield but nowhere else. I have added coolant and it has seemed to be fine. The car usually runs around 210-225 degrees, any ideas?
Old 01-03-2007, 11:36 PM
Pressurise the system and look for the leak.
That's what i would do.
Old 01-04-2007, 07:35 PM
misfit6794's Avatar
Still can't find a leak I looked at every fitting and everyhose, there isn't even any coolant on the ground. But it definetly smells like coolant and still runs up to 220, mabye this is normal?
Old 01-05-2007, 10:04 PM
strabo40's Avatar
I bought a '96 DeVille about a month and half ago and I had a leak also, but it was coming from the front passenger side. It turned out to be a crack in the plastic where the hot water hose connects to the radiator. Before I fixed this the tempature would run as high as 215 degrees, but once I replaced the radiator it typically runs aroun 205 degrees. Now I do not do a lot of driving at any one time so this could be a factor.
I would definitely take it to a garage and have your system pressure tested. Check your oil dip stick and see if your oil looks like chocolate milk. If it is then you have a leak from a gasket from the engine and this is where your coolant is coming from.
Good luck
Old 01-05-2007, 11:10 PM
misfit6794's Avatar
That is exactly where the smell is coming from, the plastic cover on the passenger side. There is a definete gap where the heater hoses go in, it looked a little too big to me. What did you have to replace to cure the problem and how much was it?
Old 01-05-2007, 11:12 PM
misfit6794's Avatar
Sorry it is the plastic cover that is on the firewall where the gap is.
Old 01-06-2007, 08:44 PM
strabo40's Avatar
With the gap being next to the firewall, my guess the leak would be at the heater core. I would check that. Check on the inside under the glove compartment and see if it is damp there.
BTW, I changed the spark plugs in my caddy and it was an easy job.
2thowEldoggHogg
05-31-2008 10:49 PM
Cadillac Allante FAQ
03-29-2008 03:51 PM
Adam K
08-23-2007 04:05 PM
belagatyo
04-24-2007 10:31 AM
Quick Reply: Cooling system
