Climate control
Old 04-04-2008, 07:59 PM
wetoddid's Avatar
Default Climate control
Hey guys. Raise your hand if you hate Cadillacs attempt at climate control. No matter what I do, I cant get the air to blow out of the front vents (to my face), it only comes out of defrost and some on the floor I think. Whats the deal?
Also, I'm getting 27 mpg on my '93 with a 4.9l(yes, I checked it mathimaticaly). Anybody else have any good milage reports?
Old 04-04-2008, 09:48 PM
Default RE: Climate control - 1993 Cadillac Devile
ORIGINAL: wetoddid
IF I was getting 27 mpg, I be smiling every minute of the day.
Climate control - doesnt you car have a adjustment for air flow going "normal" and then a slide for a combo of "down and up" .. up means the vents, down means the floors. try taking it out of the "normal" and see what it does as you slide the lever around.
Old 04-05-2008, 11:16 AM
When temp is set at 60 where does air blow out? Also check for vacuum leaks near vac. reservior on firewall.
Old 10-09-2008, 12:58 PM
No kidding! What is the deal with Cadillac's climate controls??? I'm having similar issues with my 1988 Brougham.
Old 10-10-2008, 12:26 AM
Love Cadillacs, but the worst climate control in the world. Mine comes on, but goes right back off. Had an 89 Brougham, same thing worked when it wanted to. Mostly blowing from floor.
Old 10-10-2008, 12:19 PM
carnut's Avatar
You have a loss of vacuum. When that happens its designed like many other cars to blow from defrost.
Old 10-10-2008, 10:00 PM
If your system is working correctly, you should have no problem getting it to blow out the dash vents. My 98 blows out the dash vents most of the time. Only when it gets cold outside does it shut off the dash vents and then it blows out the floor vents. I have to push the defrost button to get anything to come out of the defrost vents.
chuck
98 Deville Concours
dray5mil
12-20-2008 01:18 PM
2000ESC
05-31-2008 07:21 PM
derby98
10-09-2007 09:07 PM
carl.r.johnson
09-18-2007 01:46 PM
lenny lincoln
04-17-2007 09:17 PM
Quick Reply: Climate control
