A/C Actuator Calibration???
Old 05-14-2011, 10:00 AM
Primo55's Avatar
Default A/C Actuator Calibration???
have a 2003 deville..ONly issue was A/C would not flow thru dash on every try.it would work every now and then..found that it was the actuator on drivers side..bought and replaced xactly as i removed it..NOW air flow is completely OFF! most flow is thru the defrost,very low at dash and bottom..after calling a few places i was told i had to calibrate the whole A/C system..i know i bought the rite part,got the original at the Chevy dealer..i have NO idea how to calibrate the A/C system!! cant find any post online for a 2003 deville with this issue..Any and ALL advice is greatly appreciated,Thanks -
Old 05-14-2011, 12:08 PM
gmtechs's Avatar
just disconnect the battery voltage wait 2 min
reconnect
clear all codes
should be good after that
Old 05-14-2011, 04:36 PM
Primo55's Avatar
just tried it,disconected the power on main battery under back seat,waited for about three minutes..and same results..Been askin around,been told it needs calibrating,will that fix it or r they just trying to get more $ out of me??other mechanic said that on the ac panel on dash u push three at the same time and that resets it...whAT DO U GUYS THINK??? tHANKS.
Old 05-15-2011, 05:12 PM
gmtechs's Avatar
Service Information
  1. Turn OFF the ignition.
  2. Remove the battery positive voltage circuit fuse of the Instrument Panel Control Module. Important
    The module memory will not clear if the battery positive voltage circuit fuse is installed in less than 60 seconds.
  3. Wait 60 seconds.
  4. Install the fuse.
Old 05-16-2011, 08:14 PM
Primo55's Avatar
Where is the INstrument Panel Control MOdule located??? thanks for all the help!
Old 05-17-2011, 07:54 AM
gmtechs's Avatar
the dash is the ipc module (gauges) the fuse is under the hood label should be IP 10a fuse
Old 05-19-2011, 05:31 PM
Primo55's Avatar
Thanks for all the help!
hales
08-05-2020 02:41 PM
nobde
03-07-2010 07:32 AM
jono6406
08-07-2008 06:07 PM
halesassoc
02-04-2008 06:16 PM
coocadi
12-13-2007 03:26 PM
Quick Reply: A/C Actuator Calibration???
