1994 seville stutters and stalls
Old 02-02-2008, 09:14 PM
scottncincy's Avatar
Default 1994 seville stutters and stalls
I have a 1994 sedan deville (devil ) with the 4.9 motor, had a tuneup new coil pack ect but lately after about 15 minutes or when it gets warm it starts to idle high and or stalls and when i put on the gas it tries to die also, ive also replaced the map sensor and the idle speed control. is this a common problem with these cars ? please help
Old 02-03-2008, 07:15 PM
Default RE: 1994 seville stutters and stalls
ORIGINAL: scottncincy
did it start AFTER the new coil pack or before?
checked the throttle intake for carbon?
tested TPS ?
Old 02-04-2008, 07:11 PM
SES light? Check fuel pressure.
Old 02-04-2008, 10:35 PM
i had one that did the same thing. check fuel pressure but make sure you get it to do it at the shop!! very important it cured mine of the same prob bad pump
94FleetwoodBrougham
02-23-2017 10:43 AM
RoyalFleet
08-13-2010 02:58 PM
91DeVille
04-19-2009 10:16 AM
johndem33
11-14-2008 09:25 AM
only_passenger
04-14-2008 09:31 PM
Quick Reply: 1994 seville stutters and stalls
