Antena wont go down
Old 09-20-2007, 04:12 PM
etaylor's Avatar
Default Antena wont go down
Hi I am new ,I have a 1997 Deville and except for my antenna not going down it's a great car.I noticed that my antenna motor seems to be working but my antenna wont go down and the whole time I can hear the motor and clicking.Have anyone had that problem before ? I know theres a relay on the unit and if anyone knows whats going on I really need your help. Thanks
Old 09-20-2007, 04:34 PM
Katzmans Caddy's Avatar
Default RE: Antena wont go down
Second one this week. You need an new antenna either the gears or nylon cord that pulls it down are broken. You should disconnect power to the antenna. You will gain access by peeling back the trunk liner and presto there it will be.Unplug the connector. I seem to remember that the relay is on the antenna. There are many sources for a new antenna from the dealer to e-bay and you can spend from $175 to $15. It is an easy job to replace it.
Old 09-20-2007, 04:42 PM
etaylor's Avatar
Thanks ,I really appreciate yor help.I was wondering if you knew the purpose of the relay?
Old 09-20-2007, 05:57 PM
ORIGINAL: etaylor
Thanks, I really appreciate yor help.I was wondering if you knew the purpose of the relay?
It is really a switch, supposed to switch power on and off depending on conditions of antenna mast. When it reaches the top power shuts off, when it reaches full down power switches off. Since your antenna won't come down it is not likely the relay. You hear it run because the position of the antenna is not moving to switch off the power. I seem to remember that there is a small black box on the antenna assembly and that is it.
lineside522
09-29-2012 01:36 PM
Chris90Deville
03-17-2010 01:16 AM
speedandstealth
09-09-2009 09:36 PM
mrcrx28
03-14-2008 09:04 PM
la_uno_y_unico
06-24-2006 02:33 PM
Quick Reply: Antena wont go down
