2 different codes
http://myweb.accessus.net/~090/dtcobd2b.html#bod here you go, the p code i believe is camshaft posistion sensor.... are you sure of the B code????? let me check, I'll be back, unless someone chimes in.
this will tell you what they mean..... keep in favs....
P0341 - cam sensor code is one that could lead to "no start". You should have it checked out. B0429 relates to HVAC which you may or may not want to mess with. You could clear codes and see if they come back.
sj22
08-20-2008 08:44 PM
